- MilkyWay Galaxy
This thread is for discussion of and links for hard to find, no longer made or hard to find quality parts for the 87-90 Renix jeeps, and substitute fixes...
I have started collecting the factory AC delete brackets because the aftermarket does not seem to supply them.I figure maybe someRenix Member might find it profitable to nick-knack around in various JY's, and follow through with some Q.C. checks to said OEM Renix parts, and place a surplus amount of parts up for sale in the
'for sale' area. Just a thought!!
Is it flex plates or flywheels that are forged from unobtanium?
Renix Flex plates are available
http://www.ebay.com/itm/ATP-Automat...ash=item54414ba038:g:HFEAAOSw9GhYcBE6&vxp=mtr
And it looks like this is the flywheel
https://www.amazon.com/AMS-Flywheel-Cherokee-Comanche-Wagoneer/dp/compatibility-chart/B000EQFI20
And
https://www.amazon.com/s/ref=sx_as?...74998&vehicle=1987-42-347-13-----3364-------1
I posted in another thread- no flex/flywheels for Renix, I was referring to 2.5s...........NONE!.
Note, even on the links you provided........limited stock. That said, for you 4.0 guys, you can still get them.
But, not for long.
If you've got a 84-90 MJ/XJ............save........search.......parts.
I just bought a USB 15 foot spy camera snooper for my cell phone from China for $13 delivered. It works great. Head is so small I can put it inside the combustion chamber through the spark plug hole to snoop around and see the valves.
Did you get the one you posted the link to?
Things ive noticed with the ones ive owned or seen are:
Rear wiper arms and bases with washer nipples intact
Power window regulators
Power lock actuators
Manual window assemblies that dont stop and click
Intact spring loaded throttle cables
Intact vacuum hose assemblies (can be sourced new at napa for around $60 though)
Drivers door lock cylinders
Pristine door mirrors
Nice chrome/anodized trim
Fuel line to fuel rail o rings (havent seen new replacements specifically for them)
Console lid latches that aren't broken
Lower dash trim with ash tray tabs intact and not cracked at either lower corner of the tray cutout
Full gauge clusters are nice to have for renix or ho
10 slot and 21 slot grilles are unicorn pieces
Original electric fans are harder to find that aren't cracked
Original closed system copper radiators without leaks
I think I have a pair in my parts pile."Jeep" logo OEM fog light covers.
Hoses for the Renix coolant bottle to pipe T's and from the heater core to the pipe Ts, some brilliant person designed them with two different hose IDs on each end.
The bottom hose on the coolant bottle is easy to find and cheap ($10), but the heater core hoses and the side of the coolant bottle hose to the pipe T is made of Unobtainiam right now.
8" of hose and they want $15-$40 each delivered.
I bought 2 sets delivered for about $4 each last month from one of our Jeep aftermarket vendors, but their entire stock was hard like concrete and all had to be sent back to China as they damage the heater core nipples during installation and clamps could not squeeze them they were so hard, like plastic.
