Need new replacement sentry delay module
Owl2059
Hey all, I've got a 2001 sport that's had a battery draw. I've found that it's caused by the sentry system, the lights stay and run the battery totally flat. Do any of y'all know of any new replacement modules that are available? I can only find used parts.
Or maybe it'd be worth going through the module and re-flowing all of the solder joints? I've re-flowed multiple things at this point including the window switches, I wonder if the quality solder carried over into that module.
New, 24 years later? I wish you good luck.
Grab a used spare, and then re-flow what you have.
Sentry? You mean the SKIM (Sentry Key Immobilizer Module, anti theft), or do you mean Sentinel (keeps headlights on after key off).
If the latter, are you shutting down (key off), then turn off headlights, close doors? Light should remain on for about 45 seconds, then shut off. Turn the headlights off first before shutting down.
