Rob Patterson
- Colorado Springs
After buying the Hesco head from a friend, I was given his old stroker short block because it chewed up a lobe on #5 cylinder and the gear for the distributor drive looked chewed up. He says when he removed the cam and timing cover he did not notice the spring and pin to retain the cam. He says this is why it probably destroyed the gear for the distributor drive. Would this also destroy a lobe? He says this was the 2nd cam the motor destroyed. He was not the original owner of the motor; he bought the Jeep with the motor already in it and it was already on the 2nd cam when he purchased it.
I can already tell that the cam bearings are bad but I need to figure what else I need to do to get this motor running?
I have looked it over quickly and can tell that it has the later style 4.2 crank. It is also using the 4.2 rods and Sealed Power (Sterling) hypereutectic H802CP pistons. I checked the pistons and they appear to be approximately .020" in the hole using feeler gauges. It was using Fel-Pro 9076PT 0.043" thick head gasket. I looked at the cylinders, and 2-5 look excellent with the cross-hatch honing still very visible while cylinders 1 and 6 have smooth spots. These spots don't have any honing marks visible but there is no ridge. Like I said it is smoother than the rest of the cylinder and you can't feel the cross-hatching with your finger nail. What are these spots from and are they a problem? This stroker appears to be fairly low mileage as there isn't any ridge at the top of the cylinders.
Thanks
Thanks
