gearwhine
- Denver, CO
I'm acquiring parts now for the front rebuild, The lowers are going to be coming from the front of the crossmember tucked up, and bent for clearance if the undercarriage permits it.
I'm debating on doing a radius arm set-up with one torque arm on the right, or going for one frame mounted upper (not a wishbone 3-link. 3 attachments at the frame end, 3 at axle, not including trac bar). The 3-link will take a tiny bit more work, but I feel geometry could be set up better for caster change and pinion angle. What do you guys think? Thanks _nicko_
