Question for CA smog technicians
CaliGold
Maybe this thread should be in the tech section, but I felt I would get more relevant feedback from the SoCal peeps.
My XJ is a 97 with a 4.0. I was given a 91 engine that I'd like to rebuild to put into my 97 but before I shell out the cash for machine work, I wanted to run it over with you guys.
I know there were minor variations between the years, but for simplicity, let's just say I'm just only going to use the engine block and the cylinder head from the 91.
So..... assuming my XJ passes all functional tests, can the smog tech fail me for having an older block or cylinder head? And are you guys required to verify the casting numbers or date of manufacture as part of the smog test procedure? And given that the blocks and cyl heads are pretty much the same between the 97 and 91, is it something that I even need to worry about?
I know that in California, for non-oem engine swaps, the engine going in must be the same year or newer than the car it's going into. But not sure if that law applies in this case.
Plenty of people have swapped in older blocks to newer. No issues. Both are HO, and your stuff will bolt right in basically.
I believe technically that block is supposed to be same year/newer, but how will they know? You can even make it a stroker, and no one would know the wiser as long as the visual is good.
I figured that would be. I've never seen a tech actually verify casting numbers or mfg date except 'maybe' the last smog check - not completely sure, but he was looking at the block with a flashlight under the intake/exh manifolds near the brake booster trying to read something. Should have asked what he was trying to look for.
I found a procedure document on the CA BAR site. No mention of verifying mfg date or casting numbers.
http://www.bar.ca.gov/80_BARResourc...ctions/Smog Check Manual w-diesel 8-09 V3.pdf
I hope I'm good.
