- Salem, OR
97’ 4.0L auto XJ no security/alarm. Manual locks and windows.
Like 8 years ago, I backed my perfectly working XJ into a parking spot to remove axles and do an axle and lift that got put on the back burner because of other priorities. 8 years later(this year) and several relocations(without starting the jeep(battery was dead) it at a shop now and axles and susuepnsionn are complete. BUT the issue now is my Jeep won’t start. They diagnosed it as the ecu as dead, because they got their shop 99’ ecu to start my Jeep. So I bought a 97’ ecu, it didn’t work. Bought another 97’ ecu, still no start, then bought a documented and verified working 98’ ecu, still won’t start. I have switch between the two 97’ and 98’ ecu with none of them working, the engine will only crank and crank. I toss the shops 99’ ecu in and the engine will fire and run. Now I know i didn’t get 3 dead ecus, because one was genuinly verified and recorded working the same day they shipped it. So now I’m thinking something is screwy with my jeep. Why is only one ecu working on my jeep and no other ecu is? What can cause that to happen? I’m at my wits end trying to even figure out where to narrow the search to diagnose this odd problem. I have another ecu coming that is a 99’ to verify if it’s a year specific issue or not. But from a fellow Naxja member(Ken) 97’-99’ all ecus should start any of those years, just some might cause a engine code. What would cause only one ecu to be able to start my jeep and no other ecu will? Where do I even look or narrow my search?
