braeden
- Snowmass, CO
I'm pulling my rear anti-sway off. I have the sway bar fram mounts and outer u-bolts loosened. Do I need to loosen the inner u bolts to even out the pressure or can I just pull the outer u bolts off? Words of wisdom? I also found out I have 2 broken leaf springs(or at least one of the clips that hold the packs together).
