Re: where have all the good cherokees fs gone
Just when i this close (holding my fingers very close) to pulling the trigger on a set of axles...troy had to go and post up a built mj on the "best of craigslist" thread. I thought for about 10 minutes about which was a better deal, spending a ton of money on a pair of axles, lockers, gears, driveshafts, shocks, and other things, plus finding time and a place to install all of the parts and do the necessary cutting/mods to the body of my jeep...or just buying a rig thats 90% built already and keep my xj nice for dd and camping.
I drove up to longmont sunday and looked at the truck, everything looks great on it, the few issues it has are tiny and fairly easily fixed or not even worth doing anything about. The PO worked for poison spyder customs previously and earthroamer currently and has great fab skills. Both bumpers mount using unibody plating and lots of bolts, and same with the sliders, even the bench seat is mounted using 1.75" tubing and big floor plates, meant to be the start/base of a roll cage. The spare tire mount flips around to lay on the open tailgate to get full use out of the bed space, and has mounts that go through the bed floor and tie into the rear bumper. This was meant to also be a terminating point of a bed cage.
Heres a pic of it in my apartment parking lot yesterday next to my friend aarons (LCGEEPIN) comanche.
IMAG0115
IMAG0116
My comanche has a hp44/9" combo with 5.13s and a dana300 with the twin stick conversion already done. I wanna do a 4:1 on the 300 and find selectable lockers for the axles as they are both open right now. The PO did give me a spare carrier with a mini spool installed as well as bearings so its ready to be swapped back into the rear axle, but i wanna try and find either a detroit or arb or whatever i can source secondhand before i put the spool in.
Apart from lockers the truck essentially NEEDS nothing, but there is a small list of things i wanna change and add as i build funds back up. Im glad to have 2 vehicles again, now i can stop worrying about working on the xj...just get my other door on and get it back to one color and keep it nice.
