MrSimon
- Downingtown, PA
- Properly adjust my UCAs and LCAs
- Paint and install bumpers and sliders
- Install front Aussie
- Rear SOA
- Paint the truck
- New shocks
Revised list:
1. replace entire steering assist set-up ordered & waiting
2. BUILD & relocate trackbar and steering assist ram
3. rear shocks
4. tweak fuel set-up
5. drivers door glass
6. new battery.
7. Tune-up oil & filter, plugs, clean air filter
STROKER
Lets see.
Probably something I am missing but Such is life
- Put Adj. Lca and Uca's on
- Budget boost
- remove 8.25 add D44 W/ aussie
- Wheel adapters
- Put on 33's... Need some bumpstop!!!!
- remove carpet and trim
- remove doors!!
- replace rockers
- frt. LCA skids...CHECK!!!
Josh
got a few things done today, also got to add new tires to the listupper control arms DONE!
lower control arms DONE!
trackbar DONE!
shocks
rear locker and axle swap
tcase skid
brakelines
DONT ROLL IT!
to buy:
steel for rockers
steel for front unibody stiffeners (maybe)
WJ swap stuff mostly paid for, still need rotors, pads, TREs, lower WJ BJ's, and unit bearings
taller coils DONE
to do:
weld on ruff stuff stiffeners
fab new rockers/rock rails
weld on front unibody stiffeners (after making them)
install taller coils DONE
install and adjust rock krawler control arms DONE
install new front driveshaft
install new edelbrock shocks FRONT'S DONE
install WJ steering and brakes stuff
re-fab new bumper mounts
fab new crossmember mounting system?
LCA skids?
install RE SS lines DONE
install new D30 seals DONE
maybe some hockey puck bumpstopping, if there's time bought the pucks, still need to drill them, but the coil buckets are drilled and tapped for 7/16-20
Lets see.
- Put Adj. Lca and Uca's on check
- Budget boost acos on
- Wheel adapters check
- Put on 33's... Need some bumpstop!!!! 33's check. bumpstop on front... Check
- remove doors!!
- replace rockers
- LCA skids.Check!
Josh
to buy:
steel for rockers
taller coils DONE
to do:
install new front driveshaft DONE
LCA skids?
maybe some hockey puck bumpstopping, if there's time FRONT DONE
i developed DW in the course of the week, so this weekend any and all loose joints/bearings/ends are being taken care of. both upper ball joints are toast so i'm changing all of them, the UCA axle bushings are getting changed, caster will get re-adjusted, new steering box will go in too...
fixed
oh, and the new exhaust manifold is going to go in too. and the new edelbrock rear shocks exhaust manifold in
it's getting there. my list is bigger than i originally thought.
1. Lower the XJ a little (cut the front springs, and rebuild the rear leafs)Rear leafs are Done, gotta cut the springs a little
2. Put in the gauge package into the XJ, change sensors DONE
3. Change the CPS in the XJ (can you tell which Jeep is getting neglected?) DONE
4. Put a winch bumper/winch on the MJ.
5. Figure out rear shock mounts on the XJ/fab it up
Probably more.... there is PLENTY of time to break parts between now and NAC-Fest...
THINGS TO BUY
Pay for my tires/wheels done
gears/install kit for the front 44
passenger side flat top knuckle ordering Reid knuckles
carrier for the front done
THINGS TO DO
Set up gears in the front 44
Install alloys in the rear 44 DONEEE
Set up (ALL) brackets on the front end started
build steering FINALLY got the DOM from ballistic
Mount SXs on the beadlocks (should be fun)<<monday
Alloy X joints....suggestions/comments there maybe??
