- Middle Tennessee
How's the Jeep coming along? Lockers in yet? Rear end squared away?
I hope to see this rig in person in about a week and a half.
It's locked front and rear, I reset the gears but its still got a loud bearing so its not getting dded just yet.... but we will be wheeling, it also has a bumper and winch on it as wellHow's the Jeep coming along? Lockers in yet? Rear end squared away?
did you cut the bottom of the doors off when you did the rockers or keep them stock?
what did you use to tie them into the frame rails?
looks great so far!
Is you cross member 2x6 box tubing, 3/16 wall?
FYI if your looking for a good trail fire extinguisher the kidde auto/marine is a great deal. its about 20 bucks at lowes or any marine store, is the perfect size, and comes with a decent little bracket to bolt in the jeep.
If you really care about your rig...and I seriously mean this...
Get rid of that fire extinguisher and spend some good money on a real one. Those ones, especially the kiddie brand, aren't much worth their weight in dirt.
ibdont mind the housing work, but i really hate setting up gears. i assume the 8.25 is like the dana 44 and the ring and pinion are custom fit to the housing, right?
How do you like having ruffstuff heims on both ends on the lowers? How is the ride on the street? road noise?
its amazing, it drives like a car and the noise really isnt an issue, i do notice a little extra road vibration but it gets covered up by rolling on mt's all the time.... i wont build another suspension with a crappy rebuildable joint. when a hiem goes bad ill just buy a new one and screw it in
Nice.
I figured all of the hype about heims transferring huge amounts of noise and vibration was typical forum bs.
BLING BLING!!!!![]()
