Hell yea!!!! Im gunna show up with some sensors for you and I wanna be there to witness white jeep live again!!!
Haha. You can pass it one to someone if you want. You don't need to drive all the way up here to drop off a TPS.
I dreaded that task on mine and it turned out to be ridiculously easy & cheap. I'll show ya what I did at NACFest.
Sweet, I like easy at this point. I'll have to check it out.
does the batt. have plenty of hood clearence? just in case of a roll or a tree incident it could deform the sheet metal enough to contact the batt and cause a short
Battery has plenty of hood clearance. I guess I should have mentioned it is only spaced up about 3/8".
I got a few things done last night.
- New thermostat, again probably didn't need this, but for the $6 including the gasket, why not?
- Coolant reservoir is mounted. It looks kinda odd, but it'll work for now. Basically I spun it around 180degrees and spaced out the mounting brackets so it clears my shock mounts.
- The paint on the bracket for the PS pump and idler was dry so that got remounted. As you can see, it now rides perfectly in line like it should. If you look above the tension adjustment you can just see the beginning of the joint where I cut and welded it up
- Orbital and PS reservoir remounted. Picture was taken before I mounted the orbital. As you can see I’ll have plenty of room to mount a cone air filter next to the reservoir. I ordered an Amsoil
EaAU3051 air filter and
EaPF25 pre-filter. Its more money I didn’t want to drop, but I couldn’t find anything cheaper that either isn’t oiled, won’t take 6 weeks to come in or Chinese junk.
- Messed around with the pickups on the cell again.
I got asked about how I was adapting to the 5/16" line on the inside. Well, after trying to find an inexpensive way that was short enough not to interfere with the sump, I came up with nada.
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here's what I ended up with;
Summit Bulkhead fitting ->
Earl's -8 To -6 AN Female Swivel ->
Aeromotive -6 AN to 5/16" hose barb
The Aeromotive fitting hurt to buy, but it was really the only option I could find. I
almost bought the 3/8" hose barb adapter which was significantly cheaper, but after messing with this fuel line I'm glad I didn't. It is hard enough to get it on the correct adapters.
Picture of the entire setup:
Close up of the above set of adapters:
In the tank (picture makes it seem like there is more space then there really is. Much longer and I wouldn't have room for the pickup):
And a quick two pictures of the inner fender trim.
Test fit the cut (this is 1/2" past full bump and full droop and obviously turned in). It is very tight, but I keep the battery box this way:
Patch completed:
I'm hoping to get the radiator mounted and start working on the brackets for the coolers tonight.
