DAY 1
There isn’t a lot of customization involved with this install, however, there’s enough busyness going on to make us stop and think each process through. I’m a detailed oriented person, so I look at every way possible to make things better.
As you’ve seen by my previous photos, this is a well-built radiator, arguably the best quality and most efficient radiator for the Jeep Cherokee. It’s obvious that FF Dynamics put a lot of time and effort into this kit. The attention to detail is second to none and they offer a lifetime warranty if you have it installed by one of their dealers.
With that being said, I did find through my research some debate to whether or not the fan controller (that comes supplied with the kit) can handle the draw of all three fans simultaneously. According to the manufacturer, the fans have a low amp draw of 5 amps per fan at full speed, but that doesn’t account for the initial draw. One remedy to ensure the draw is to use a 75 amp relay to supply the fans. In other words, the advice that was given to me is the advice that I’m posting here, and that is to use the controller to trigger at least a 50 amp relay to supply the fans. Otherwise, the fans might not pull as much air as they should due to a lack of current.
Even though the controller comes with a 30 amp fuse, that may not be enough protection. If the 30 amp fuse blows, then I have no fans. Since I no longer have the mechanical fan, blowing the fuse is one risk that I don’t want to take. For this reason, I decided to use one 30 amp relay and 30 amp fuse for each fan. The fans will be triggered by one lead from the fan controller.
Okay, so on to the install. The radiator and electric fan kit was installed without any problems.
Instead of using the OE transmission hardline to connect to the radiator, we plumbed the aftermarket transmission cooler to the radiator’s upper transmission outlet.
The transmission will now flow through the radiator cooler to the external cooler and back to the transmission return line. After leaving the external coolant filter, the line is tucked behind the front bumper and is plumbed to the transmission filter. Not only is the filter in a safe place, but it’s going to be very easy to service.
We ended the day by finding a mounting location for the controller.
Here's the added relays for each fan.
