PPW 170 amp Alternator & Mobi Arc Underhood Welder
Kaczman
Lurker
Brighton, CO
I have an older but hardly used Premier Power Welder 170 amp alternator. It includes all wiring and an external voltage regulator. Its the earlier 6-10 mounting seen here:
http://www.premierpowerwelder.com/specs/PP170CS.html
$200
The alternator is wired for plug and play with a Mobi Arc 200X under hood welder. Perfect for those late night trail fixes. Its saved me more than once! It comes with all wiring and a hand throttle for ultimate welding control.
http://www.perfectswitch.com/mobi-arc/
$300
Buy both and I'll throw in the 30' welding leads, some spare welding rod, a chipping hammer, and brush all in an ammo can for a ready to go package.
-Jon
Moving Sale! $350 for everything... Alternator, welder, leads, hand throttle, welding rod and instruction manual.
GO FRED!!!
I too, am enticed, and staring at my skinny ol' piggy-bank.
Dude, I know you are much more knowledgable than I am in the area of welding, go for it. I can barely weld with flux wire, stick welding might be beyond my learning curve.
Dammit Fred! You were supposed to buy this, and save my skinny arsed piggy-bank.
FWIW, I did cross post this ad on another board. :)
Fred- These OBW's are actually pretty easy to learn on. By varying RPM or rod diameter, fine tuning is a piece of cake! Even you're not too old to learn something new. :)
Dude, you play harder than I do, go for it. :D
