machinisttx
- texas
Disclaimer: Everything below will apply only to 4.0L equipped XJ's.
Starters: Several months back I had some trouble with the starter on my '00 XJ and spent some hours searching for info on rebuild parts. I had no luck initially and took my starter down to the local rebuild shop. Luckily I had a spare starter that Swamprat had given me(thanks!). I tried again later and came up with some real info. The 4.0L XJ's are equipped with a Mitsubishi PMGR series starter. As far as I can tell, there's no significant difference between year models. I could be wrong on that, so please don't take it as gospel. I am aware that the connector for the solenoid is different between early models and late ones, but that is pretty easy to deal with. While I'm on this subject, I found replacement solenoid side connectors for anyone interested. http://www.aspwholesale.com/index.php?act=viewProd&productId=7772 There are also two different solenoids with that connector already on them, with the only difference being the direction the connector faces. In any case, that connector is attached to the solenoid on my starter with a screw and a nut, so it can be removed and put on a solenoid for an earlier model(which is what I did rather than hack the wiring).
Unfortunately, I haven't found a "kit" to rebuild the starter, but the company linked above does have all the individual parts to do the job. You'll have to search through the "application guide" with is on the left side of the page near the bottom. Just search for jeep cherokee and your year model. It will also pull up the alternator info below.
Alternators: I went outside a short while ago to have a look at the alternators in my '00 and '91 XJ's. To my disappointment, I can't read the stickers on either one. From the site linked above, it should be a Nippondenso ER/IF series for my '00 XJ. The rebuild/repair kit part is here: http://www.aspwholesale.com/index.php?act=viewProd&productId=6050 That may or may not(it isn't for my 91) be the correct kit for your alternator, so use the application guide search to be sure. They do have 220 amp upgrade kits for some of the ER/IF series, but I'm not yet sure if they have one for the Cherokee alternator. I have found them for the grand cherokee alternator and several other common chryslers. All of them are around $200 anyway. Someone else might have them too, I haven't searched to the end of the internet to find out.
I don't know if it's ever been mentioned here or not, but for what it's worth, it appears that the alternators on these are externally regulated. I'm not sure yet whether that's handled by the ECM/PCM or a separate regulator. From what I've been reading, it appears that chrysler decided some years ago to have the ecm/pcm manage it, but I don't know when it started or on what models. Good news is that it makes it a little easier to convert one to a weldernator for anyone that wants a cheap on board welder.
