I just heard that Nissan is in talks to buy Jeep...
This should be interesting.
Not the Chevys
X2
The 4.0 is a great engine, but its a dinosaur, its a wonder they kept it alive as long as they did. 4dr JK=Modern XJ
Huh i thought they did oh well i would buy a Dodge with a Cummins anyways if i was getting a 1 ton
:doh:
A chain is always as strong as it's weakest link![]()
gm now nakes a z71 that is two wheel drive... its just an appearance package. what else can be said for their offroad capable vehicles... or lack there of.
There's also plenty of 2wd trucks in the dirt now. It's not just crawling anymore. Z71 upgrades the shocks, tires, lifts it an inch or two, adds skid-plating, and in some cases a gov-lok rear diff. More than an appearance package.So 202hp and 237ft/lbs (jeep.com) is wayyy better than 190hp and 235ftlbs?
And as far as fuel economy? are you serious?
3.8L V6 best: 16.11 mpg
worst: 12.26 (Four Wheeler, April 2008, Long Term test.)(2dr model)
4.0L I6 best: 18.18
worst: 15.30 (personal tests, conducted over 5 tanks of gas)
I realize that it would have been a pain to get a 4.0L to meet current day emissions tests, and to also retool their factories to keep making the 4.0, but i see the 3.8L as a compromise, not an upgrade to the 4.0L. With modern day techonology on the 4.0L i have no doubt that it would make more power, and get better mileage than the current 3.8L V6.
More HP/torque from a smaller displacement is an improvement if the new motor is using the same or less gas. Unfortunately, in different chassis, it's almost impossible to test.keep in mind that they're being used in larger heavier vehicles than the XJ and the 4.0. Also, more power and equal torque from less displacement is an improvement in my mind.
I hear that a lot, but I wonder about it. Combustion chamber/piston dome shape and cam profile are easy to change without changing the basic engine. 'Biggest pain on a 4.0 would be converting to a roller lifter system to get a modern cam profile. OK, so new head casting, new piston dome. Maybe a new intake and exhaust. How many head designs/intakes/exhausts/piston designs have there been for the AMC I-6?I realize that it would have been a pain to get a 4.0L to meet current day emissions tests, and to also retool their factories to keep making the 4.0, but i see the 3.8L as a compromise, not an upgrade to the 4.0L.
2)It's comparatively big(long)
ill probably be the only one in the world to say this, but if this buyout does happen, i will give up on chrysler and move on to ford![]()
the whole reason for switching to ford is the solid front axle.... and if dodge ever does make the switch to ifs, i would trust it more then any toyota:jester:... o and lets not forget, toyota doesnt make a truck heavy duty enough to deal with what i need it for:dunno:at least move to something decent!! Like Toyota.....
They will be soon. Google 1 ton Tundra or Tundra HD. They've rolled out dually prototypes, have been hinting at a diesel, etc.the whole reason for switching to ford is the solid front axle.... and if dodge ever does make the switch to ifs, i would trust it more then any toyota:jester:... o and lets not forget, toyota doesnt make a truck heavy duty enough to deal with what i need it for:dunno:
yep, infact i believe the JK is the only one still running a straight axle. the new grand cherokee is IFS
Looks pretty good, and if the diesel performs like that 5.7....:drool:actually ive been in and seen the new proto type.
it was at the world Ag expo here in california this year.
its actually not a bad truck.
but were going to have to wait and see.
