Cujo
- Magnolia, Delaware
I've got a '94 XJ, running 35's, front end is D-30, with TJ shafts, 4.56's and Lock-Rite. Whenever I'm in 4wd (lo or hi), and I get on the gas, or climb a hill, or pull someone out, (basically, under stress) I get a popping sound from the right front end. It sounds like it is coming from the right hub area. It did it both when I had stock gears and open diff, and now with 4.56 and lockers. It almost sounds like the outer shaft is slipping in the hub. Anyone ever heard of this? Any other ideas.
