I was looking at numbers tonight (for shits and giggles) and did a drawing so I could see the difference in pinion height when applied to drive shaft angles.
What I was thinking was since most of the time the pinion is rotated to set the angle to 0 degrees at the diff yoke that the actual height of the driveshaft doesn't change that much except in extreme cases. My theory was somewhat true.
What I did was took some ruff measurments from my junk and turned each housing up to set the driveline angle. I took a measurment to the centerline of the pinion joint and then one at about the midpoint between the centerline of the axle and the t-case output. The below is skewed a little because I did not take into account the way the CV curves the angle at the output. The measurements were to the yoke. All of the pinion offset and lenths were based off the info in True Hi9's site and I assumed a daytona pinion support for both the Hi9 and Low 9.
Centerline of axle to t-case output - 45"
Ground to centerline of axle - 17"
Ground to centerline of t-case output - 28"
The yellow looks like pink in the pic. I'll let you decide what that means.
