Root Moose
- ON, Canada
LOL! No doubt.Lincoln said:Oh and Moose, I think even with 1/4" tubes the housing weighs more than two sami axles.![]()
I guess my point is that in a light vehicle with relatively light axles it might not be that much of a big deal since everything is "balanced" (sorry - correct word/scenario escapes). But, in the case of a heavy vehicle (I don't care what weight you trim, an XJ is a pig in comparison) if you remove too much weight from the bottom you are effectively raising the centroid and adding to the potentials that raising the center of gravity implies.
I am of the opinion that gun drilling the shafts is not something that is desired if weight reduction is your goal. It is the wrong part of the vehicle to be trimming weight (within reason) given the normal Dana/9" style axles and an XJ body. Considering an all out buggy, well even then I'd need to be convinced.
Now, if you were talking about something silly like Rockwells, fill yer boots and gun drill away.
