- Michigan
the blue alum is going to be painted, as will the cage, I just got the jeep home last night and still have some work to do, but here it is.
CRASH said:Ugliest thing I've seen since the "short bus".
CRASH
Fore Wheeler said:the 'a' and 'b' hoops are welded to my rocker, which is then braced back to the frame, lca mount and rear/front spring hanger, the 'c' hoop is welded directly to the side of the frame, and the 'd' is on plates that are welded to the top of the rear/rear spring hanger.
good stuff.
don't forget to get a case of pool noodles
Beezil said:don't forget to get a case of pool noodles
Okie Terry said:Hey FW, I started an Off Topic thread a couple of weeks ago for you to show me some in-n-out pics of your bus. Would you indulge me please?
Fore Wheeler said:got some yellow bar pads ordered, they're $2 per 3' (cheap 'nuff), 'sides, I heard that if you wheel in a sport coat you should not use pool noodles, it may tear the threads.
I was going to steal the insulation from the plumbing that we have here in the house, but ang put the stops to that.
