PART OUT: Crazyjim's 2000 XJ Jeepspeed Prerunner
crazyjim
SoCal
This is a pre-emptive selection thread... not a feeler as I've made the decision to part it out already, I just want to get a feel for who wants what and start getting people in line.
I won't start the part out until I have the shell sold. It's a 2000 shell in great shape, it will come with:
  • HO Motor (83K~)
  • AW4
  • NP231 (AA SYE)
  • TNT Frame Stiffeners
  • T&J Frame Stiffeners
  • TMR Front frame plates
  • Fully Tig Welded 1.75" cage.
  • All wiring / harness to keep it running
  • Dash / Gauges
I have a buyer lined up for this, but if he falls through, would like to have some other interest. I won't sell the shell with the cage for less than $3500. It's a fair price, for a running drivetrain and a tig'd cage.
Other items that will be for sale are as follow; keep in mind I do not have prices set on these yet.
  • 12" Travel Bilstein 2.65 Piggy Back resi shocks w/ ACV Valve (Brand New)
  • 17" Travel Bilstein 2.65 "Big 60's" Double Bypass's w/ ACV Valve (Brand New)
  • 2" Travel Bilstein 2.0 Bump stops (Brand New)
  • Deaver 5.5" front Coil Springs (Brand New)
  • Deaver Jeepspeed Leafpack (Deaver re-built)
  • 5 AR23's w/ 33x10.50x15 BFG A/T's, powdercoated black (95% tread left)
  • Trussed / Sleeved D30 with NEW 4.88 gears
  • Chrysler 8.25 29 Spline w/ stock gears
  • Brown Dog Motor Mounts (Brand New)
  • Ballistic Heim Steering kit (Brand New)
  • Ballistic Trac Bar kit w/ heims (Brand New)
  • Custom Built adjustable .250 LCA's with 1.25" Heims
  • Custom Built adjustable .250 UCA's with 7/8" Heims
  • Teraflex High Steer Knuckle (Brand New)
  • Pitman arm milled to accept 3/4 or 7/8" bolt for heim steering (can't remember)
  • PRP Daily Driver race seats (Brand New)
  • Crowe 5 Point Harnesses (Brand New / Expired for racing)
  • Ruff Stuff D30 cover (Brand New)
  • T&J Front Upper Shock Mounts
  • T&J Front Airbump Mount kit (Brand New)
  • Glassworks Front Fiberglass fenders
  • Rear Spring plate / Shock Mounts (Brand New)
I know I'm forgetting stuff, I really need to get out into the shop and figure it all out. Again, this stuff will all be included in the part out, unless someone walks up to me with the right amount of $$$ to take the whole thing. It's literally 90% done, and just needs a few good weekends to wrap it up. You can see pictures of most of this stuff, and all the cage work in my build thread. I'll get a few select pictures posted up here shortly.
Build Thread (Go to end for current pics) http://www.naxja.org/forum/showthread.php?t=983758
Pics:
I'm intersted in the 2inch bumps and possibly the 12 inch shocks.
Shoot me a price for the whole thing... I'm in the market.
Welp, it looks like this is probably going to be a go. I'm going to try to form a "line" for people who want the same parts, but if the whole thing goes at once then I'll sell it that way.
PRICES:
$600 - 12" Travel Bilstein 2.65 Piggy Back resi shocks w/ ACV Valve (Brand New)
$1000 - 17" Travel Bilstein 2.65 "Big 60's" Double Bypass's w/ ACV Valve (Brand New)
$300 - 2" Travel Bilstein 2.0 Bump stops (Brand New)
$225 - Deaver 5.5" front Coil Springs (Brand New)
$500 - Deaver Jeepspeed Leafpack (Deaver re-built)
$750
- 5 AR23's w/ 33x10.50x15 BFG A/T's, powdercoated black (95% tread left)
$500 - Trussed / Sleeved D30 with NEW 4.88 gears
$100 - Chrysler 8.25 29 Spline w/ stock gears
$50 - Brown Dog Motor Mounts (Brand New)
$200 - Ballistic Heim Steering kit (Brand New)
$100 - Ballistic Trac Bar kit w/ heims (Brand New)
$250
- Custom Built adjustable .250 LCA's with 1.25" Heims
$200 - Custom Built adjustable .250 UCA's with 7/8" Heims
$350 - Teraflex High Steer Knuckle (Brand New)
$15 - Pitman arm milled to accept 3/4 or 7/8" bolt for heim steering (can't
remember)
$400 - PRP Daily Driver race seats (Brand New)
$100
- Crowe 5 Point Harnesses (Brand New / Expired for racing)
$80 - Ruff Stuff D30 cover (Brand New)
$50 - T&J Front Upper Shock Mounts
$100 - T&J Front Airbump Mount kit (Brand New)
$300 - Glassworks Front Fiberglass fenders
$50 - Rear Spring plate / Shock Mounts (Brand New)
All prices are OBO... some have more wiggle room than others, some have none. These parts are almost all brand new, and come in way under retail, plus they're tax free :D :kissyou:
OR
Buy the whole thing for $8000 out the door... plus whatever other Jeep parts I have that I'm forgetting.
Put me in line potentially for the seats and the harnesses. Also, the front bump stops and mounting kits.
David Bricker / SYR
Interested in ballistic steering, and pitman arm. Is it a drop arm? Pictures of steering setup?
Nevermind on pictures saw them in the thread. I want the upper arms too.
Price list is up, need to get you confirmed on this stuff if you want it! Also were you interested in the Teraflex arm as well? It's milled out to accept the large bolt for the steering you're wanting. If you want that along with the steering I can cut a deal, even more if you want the track bar.
I'm interested in the springs and leafs, motor mounts and spring plates.
Also is the D30 open carrier or does it have a locker in it?
Sounds good, I'll put you down for them. The front end is open.
whats the new plan? So I take it you don't need that front spring hanger?
Hehehe, I still may take it, just so I can fab another one and sell the set (which is what you should do!)
As for the plan, going with some dirty hooker travel, mid 90's F1.
How many harnesses? (guessing atleast 2)I'll take them if david doesn't.
Edit: Just saw the pics and don't see a back seat. still interested if david backs out.
