Parking brake cable for an 8" 2000 XJ w/DANA 60's
Thanks! that guy said he called Custom Cables Inc., 1-562-802-1122. Ill need to check there prices.
i would assume they will be expensive.
here is a universal kit
http://www.currieenterprises.com/cestore/ProductsRE.aspx?id=1541
i would just find some vehicles at a junk yard with the same rear axle as you and pull the e-brake cable.
what you need is a cable that mounts to the e-brake harware of the d60 you have and then figure out a way to adapt the cables to the mount/junction under your jeep.
