YJ front lines will gain you some length, relocate where the body mount is and you can gain even more length. Another swap is I believe mid 90's GMC IFS 1/2 ton front brake lines. They're even longer than the YJ lines and only take a touch of grinding to get the banjo bolts to fit, depending on your calipers.I might be able to use some lines from a dodge truck or something. I'll look at the yard.
^ good info to know about getting new ones made. I just did what you recommended and straightened and moved the bracket down. my bumpstops will either bottom out or my wheels will hit the fenders before I run out of brake line. but brad is a picky SOB so he will probably want gold plated brake linesmwahahaha
edit: Are you saying the rear MJ lines for ebrake or regular fluid lines?
