muduck18
- Geigertown, PA
cool, that's what I have, rockin 33's and a 5sp trans.
Hopefully it isn't the gears causing the vibrations. It may be what I ran into with mine when I went from 3.55's to 4.88's. The driveshaft turning faster than before was pointing out a bad ujoint. Swapped that out and it ran much nicer.
x2 same thing happened with me. Turning 2700 RPMs on the highway as opposed to about 2300 RPMs makes quite a difference. Revealed the bad slip joint in my front driveshaft REAL quick.
Rumor has it, they can be used in the rear of an XJ with the ax15 and an SYE
hey let me know when you're going to the junkyard. If I'm home I'll go, I need some stuff. Or you can just pick me up stuff.
