Off Board 12 volt Air Compressor recommendation?
Maz
LaCanada, CA
I am looking for a stand alone 12 volt air compressor for tires (up to 80 psi), inflatables, all around use.
Is there one that comes highly recommended?
TIA .. Maz
If you don't mind clamping right onto the battery terminals, try to find the Tsunami (Master Flow) MV-1050, otherwise known as the "Pep Boys" compressor. Should run you around $50-75, depending on where you can find it.
Performance is comparable to the more expensive models (e.g., Viair) but at a much better price. I love mine.
Rob
