No start, P1694 code
Anothername
Pa
So here is my issue. Ive been working on the jeep a little and managed to do two things. I welded on a second battery tray, and I pulled my ac evaporator from the dash. Now, when I go to start the jeep it just turns over and gives me the P1694 code. Additional info, I did cross feed the battery for a few seconds trying to jump it thinking the battery in the jeep was bad. I finally put a different battery in the Jeep and it's still throwing the same code. I did a little digging and I pulled the cps to see if the dash gauges would come on once I removed it. Still the gauges don't seem to come to life with the cps in or not. Anyone have any advice? I'm not sure if I might have fried the ecu cross jumping it, or maybe welding near it? Or did the dash removal disconnect something when I pulled it back to put in the evaporator?
Problem solve for the Trouble Code(s).
If you have a P1694 suspect a faulty Crankshaft Position Sensor (CPS). The CPS must be tested before you proceed. In the past there have been reports that the TCM has caused similar fault(s). Try unplugging the TCM and see if the NoBus message ( if present ) goes away and all gauges work. If so, replace the TCM.
Inspect and test the CPS wire plug and wire harness for loose/bent/damaged connection pins, corrosion, and damaged wires. Inspect, clean, and tighten firmly the two ground wires at the ignition coil. They also are ground locations for the transmission computer.
P1694 Fault In Companion Module. No CCD/J1850 bus messages received at the power train control module (PCM) from the AisinWarner Transmission Control Module (TCM). P1694 will set if no CCd bus messages are received from PCM for 20 seconds or invalid messages are received for 20 seconds.
Possible Causes
- Faulty Crankshaft Position Sensor.
- Faulty TCM.
- CCD Bus (-) circuit open between PCM and TCM.
- CCD Bus (+) circuit open between PCM and TCM.
- Transmission CCD bus wiring damaged
In the past there have been reports that the Transmission Control Module (TCM) failures and Keyless Entry (RKE) module failures have caused similar symptoms and faults. Note that the RKE module is on the CCD Bus. Try unplugging the RKE module and try unplugging the TCM and see if the NoBus message goes away and all gauges work. If so, replace the TCM or RKE. Engine sensor wire harness/wire plug issues, a faulty CPS, or a faulty TCM should be the first suspects for a P1694.
Read this >> http://www.naxja.org/forum/showthread.php?t=63167
When the CPS short circuits the engine computer (PCM) shuts down to prevent damage to itself. As a result, there is no communication (P1694). Disconnect your crankshaft position sensor then put the ignition key in the on position. If the instrument cluster voltage and fuel gauges start to work once the CPS is disconnected, then you know the CPS or CPS wires are shorted and is the root cause of the codes. You can verify this by testing the CPS and checking continuity and voltage on the CPS wires.
P1694 Diagnostic Procedure
1. Check instrument cluster gauges for proper operation. If fuel gauge and speedometer operate properly, go to next step. If fuel gauge and voltage meter do not operate properly, test the CPS.
2. Turn ignition off. Disconnect Gray PCM harness connector. PCM is located at left front of engine compartment. Disconnect TCM harness connector. Measure resistance of CCD BUS (-) circuit (White/Black wire) between TCM harness connector and Gray PCM harness connector. If resistance is more than 5 ohms, repair open in CCd BUS (-) circuit (White/Black wire). If resistance is 5 ohms or less, go to next step.
4. Measure resistance of CCD BUS (+) circuit (Violet/Brown wire) between TCM harness connector and Gray PCM harness connector. If resistance is more than 5 ohms, repair open in CCd BUS (+) circuit (Violet/Brown wire). If resistance is 5 ohms or less, replace TCM.
5. Conditions necessary to set DTC P1694 are currently not present. Inspect related wiring and harness connectors. See WIRING DIAGRAMS. Repair wiring as necessary. If no problem is found, check for broken, bent, backed-out or corroded wire terminal pins. Check for chafed, pierced or partially broken wires inside insulation. Repair as necessary.
