syco_venom
- Indianna
2000 XJ 210kish miles, engine rebuilt 15k miles or so ago 4.0 automatic mostly stock outside stereo no immobilizer, or aftermarket remote start installed. Vehicle last started in December, and drove fine. Needed it in January and it wouldn't start, but was too cold to really work on till recent. Starter tries to crank it it just doesn't fire. I got the infamous no start no bus error I've already tried a lot of things that I gleamed off prior posts on this, but not sure if I'm missing something. When I put the key into the on position the relays chatter. Specifically the Fuel pump relay, the AC relay, and the ASD relay. If I unplug the fuel pump relay, and AC relay the ASD relay gets louder. If I unplug the ASD relay the other 2 don't make a noise(still no bus though I thought maybe there was a short on the injectors or something). Things I have tested I've disconnected the CPS sensor and the others hooked to that 5v rail, and tried it still no bus. I then reconnected all of them except the throttle sensor so I could test the voltage on the rail and its 5V even with the other sensors on so there shouldn't be a short to ground. I cleaned up the grounds that are on the dipstick holder, under the ECM, and tested the ground strap on the engine. I also went through and tested the grounds on the plug that plugs into the ECM all show continuity to ground. I'm not sure if I missed any grounds as I couldn't find a very comprehensive list. I tested the power lines using the pinout for the plug going into the ECM and they tested fine. I pulled every fuse under the hood and tested them, I swapped out the relays with known good ones still no change(and put back the originals). I also tested fuse 11 in the cab passenger side fuse panel. I even bought another ECM, and still no change. I got the 2000 jeep service manual which is where I pulled all the pinouts from for testing purposes. The only thing I haven't tested yet is the ignition switch that I read could be an issue, but I couldn't find a testing procedure for that as the links people put in the posts were dead. Any help would be much appreciated
