new radiator and install q's
the_chief
denver, co
So from searching naxja, I've got my finger on the trigger for a 3 row cfs for 148 shipped. This will replace the stock radiator on the 88 cheif that ****es out of the seams.
Anything I should know before the install, what to look out for? Something I should have handy? Any suggestions on what to replace, along with it? I've replaced upper and lower hoses, but that's it.
Thanks in advance-dave
Go to Carquest or the dealership and get a new fan clutch. It WILL need replacing. Also, get a lower hose and upper hose from the dealership also. You may as well redo the t-stat too.
Just have a bucket ready for the antifreeze, and taking your entire front clip off is helpful in getting to everything.
When you reassemble the front, put your fan shrouds in before the new radiator. With the new rad being thicker, you will have a major pain if you dont put the shrouds in first.
HTH
Fergie
One tip to help when removing the old radiator & installing the new one, is to get a piece of cardboard that is about the size of the radiator. When you get ready to pull the old one, stick the cardboard between the radiator and the shrouds & fans. This holds all that junk out of the way and allows you to remove without getting caught up on the shrouds. When your ready to put the new one in, the cardboard keeps all that junk from getting in the way and denting the new fins.
Not a big deal, but it makes it easier to get in / out this way.
How many miles are on your water pump? The reason I ask is because its SO much easier to change out with the radiator and fan clutch out. They're fairly inexpensive too, just dont get a rebuilt one.
Any special tool I might need for a fan clutch or the radiator? I have the manual, and good hand tools. Will the rad bolt up like the old one? I've never replaced a rad or fan clutch, but I'll give it a try.
The radiator should bolt up just like the one you're taking out. No special tools anywhere. The fan clutch is 4 bolts...piece of cake. I swapped everything on mine including the switch from closed to open systems, and including a stop for some beer and bratwurst, it took 4 hours. Remember to use distilled water. No point in getting a brand new system and gunking it up with tap water. And I second the motion to replace the pump while you're there, unless it's relatively new.
-Rich
thanks for the quick reply. the rad will be here friday.
i just called pep boys, and he asked if i wanted the 160 or 195 deg thermostat. I'm assuming 195?
BTW the next sob parts guy who asks if it's the compact cherokee is gonna get it!!!!
Get the Tstat and gasket from the dealer, it has the correct bypass hole. Install the tstat with the little hole at the 12 O'clock position. Same with the pressure cap, OEM dealer and if you really want to save yourself some trouble down the road do the hoses also. Again, dealer supplied, the new OEM heater hoses will have the clamps already on them and the lower rad hose will have the anti-collapsing spring in it as well as the hose protectors around the outside. They also fit and are not 'generic', have the correct sized ends and bends.
When removing the heater hoses don't pull or wiggle them off, instead slit them with an exacto knife or other razor knife length wise then peel them off gently. Break one of those heater core bungs off and you just added a couple of hundred dollars and 8 hours of labor to the job.
Just a thought and I'm going to try this myself the next time I drain my system in the driveway and don't have access to the machine. Hook up a wet/dry vacum cleaner [strong one] to the top radiator hose disconnected from the radiator, plug the radiator top bung and turn the shop vac on, this is after you have done the initial drain of the system unless you have a big tank I'm thinking :D . After using the air run snap-on coolant flush machine this may do the same thing and evacuate more coolant. Remember also to turn on your heater so that coolant can be removed from that too. What I don't know is if a shop vac can generate enough vacumn to do what the snap-on machine does with shop air, it might work but dunno know for sure. I do know that it will take longer if it does.
Remove the overflow bottle, drain it and clean it out, put it back in and refill with new mix to between the hot and cold mark.
When it comes time for refilling have two gallons of mopar coolant and two gallons of distilled water. Initial fill just dump in the first gallon of pure coolant and one gallon of distilled water, thats a 50/50 mix, then dump half the other gallon of distilled water into the empty coolant jug, top off with pure coolant and add the remaing half gallon of distilled water to the half filled pure coolant bottle, that gives you two 50/50 mixed gallons in the correctly labled jugs.
Now comes burping the system, take about 30-45 minutes, nose up a bit.
Start her up, top off with coolant and let it bleed air out, you can see the air in the top filler hole of the rad if you keep it full to the neck, it will look like fuzzy green soda, just let it run and keep it topped off till there is no more fizzies. Once you are convinced that all the air is out, engine running, race the engine, coolant level in the neck drops, quickly top off, pop cap on and the system should finish bleeding itself from there over the couple of days.
Before I did any of this I would drain the system, add a bottle of prestone 7 hour flush and refill with water then drive it, with the heater on. Might as well get as much gunk out of the old system as possible especially the stuff in the block and heater core. Then backflush it with the prestone kit. Then do the cooling system stuff you had planned.
