Need Dual Battery Tray Suggestions
BobCSmith
Phoenix, AZ
Need Dual Battery Tray Suggestions.
Searching the forum I've only seen one picture where each battery is on each side of the engine compartment. Does anyone have other pics of their set-up?
I read someone suggested using a XJ d.side battery tray.
Does this easly fit in, or do you need to do some modifing to get it to install?
Any help is appreciated.
Also, to those with Dual Battery Set-ups, have you found this to be a beneficial upgrade?
Just curious, why both in the back? What's the advantage of moving the location of the stock battery? I considered mounting one in the rear cargo area behind the passenger seat, is this where you are talking about? I do like both in the engine compartment unless there is a real advantage to installing it in the rear that I'm not thinking of.
