Lowrange2
- Abbeville, SC
Finally! Another person says No fly... that's 2 versus 7 or so.
ZacSquatch said:Dude... my first bet was no fly, go fall down a ditch or sumthin, lol
rocknxj said:I say all you that believe it will fly, and later find out that it does not, sell your Jeep and buy a Yota. That'll learn ya.
ZacSquatch said:Echo... Echoo... Echoooo...
ZacSquatch said:Ive got a degree and my A&P if that means anything and "techincally" an airplane prop produces lift and yes I know all about Trust, lift, drag, weight. Ive also spent a few hours crewing helicopters so if you want to talk about swash plates, gyroscopic procession or centripical/centrifical force, have at it.
Captain Ron said:LowRanger, you threw out a guess, you really don't know if in fact it's right or not, and you can't cite any reasonable source so far to explain why the wheels don't matter.
Well first of all the prop on an airplane does not produce lift it produces thrust causing speed causing air movement around the wings thus causing lift. On a helicopter the prop produces both the thrust and lift .... yes.Ray H said:Ive got a degree and my A&P if that means anything and "techincally" an airplane prop produces lift which is the source of thrust and yes I know all about Trust, lift, drag, weight. Ive also spent a few hours crewing helicopters so if you want to talk about swash plates, gyroscopic precession or centripical/centrifical force, have at it.
Captain Ron said:If you didn't hit the side of your head, you wouldn't hear that anymore.
You know about "Trust"? me too.
You did not start out talking about "precession", etc... Has nothing really to do with what you did start out with.
Although, if you wanna play really smart guy, you'd have followed up on one particular aircraft type you just used, to use a basic, correct, explanation of what will happen on the treadmill.
--ron
impetus-93xj said:Well first of all the prop on an airplane does not produce lift it produces thrust causing speed causing air movement around the wings thus causing lift. On a helicopter the prop produces both the thrust and lift .... yes.
Ray H said:...
Real basic explanation: The plane will fly because the prop will produce thrust which will increase the planes airspeed, eventually creating enough lift to overcome weight. Notice, I didnt mention anything about the treadmill because it doesnt matter.
Im sure you have plenty to add so go ahead.
lowrange2 said:I suck at explaining and this guys explanation is decent so here.
"But of course cars and planes don't work the same way. A car's wheels are its means of propulsion--they push the road backwards (relatively speaking), and the car moves forward. In contrast, a plane's wheels aren't motorized; their purpose is to reduce friction during takeoff (and add it, by braking, when landing). What gets a plane moving are its propellers or jet turbines, which shove the air backward and thereby impel the plane forward. What the wheels, conveyor belt, etc, are up to is largely irrelevant. Let me repeat: Once the pilot fires up the engines, the plane moves forward at pretty much the usual speed relative to the ground--and more importantly the air--regardless of how fast the conveyor belt is moving backward. This generates lift on the wings, and the plane takes off. All the conveyor belt does is, as you correctly conclude, make the plane's wheels spin madly."
and of course the one thing that could lower my blood pressure , "Friend of the day", sucks right now!
