Ray H
- Falling Waters, WV
Id say he/she is niether happy nor unhappy at that point.lowrange2 said:I would assume there is a not-so-happy person inside there.
Ray H said:Id say he/she is niether happy nor unhappy at that point.
lowrange2 said:...
Once again... the wheel speed DOES NOT MATTER. The planes prop pulls it along... Technically with no friction in the planes axle the plane will not move without the prop.
Captain Ron said:I know what it's going to do. You folks are guessing, and then offering the lamest explainations for why, like yours.
I've heard more technical thinking in a third grade class room than here. At a girls school.
--ron
--ron
lowrange2 said:Well you certainly aren't offering up any explanations...
lowrange2 said:Please do enlighten us 3rd graders. I wanna hear it, Sir.
Captain Ron said:
Ok third grader, at a girls school, it goes like this:
Read FAR 91.205
Required equipment, day, VFR.
Mnemonic: A TOMATO FLAMES
A nti collision lights
T achometr
O il pressure gauge
M ainfoild pressure gauge if altitude engine
A ltimeter
T emperature gauge if water cooled
O il tempreature gauge
F uel gauge
L anding gear position indicator
A ir speed indicator
M agnetic compass
E LT
S afety belts
So, you see? It's simple. Wheels are not required for flight. The plane will fly.
You try.
--ron
lowrange2 said:Capt.?
Ray H said:Im "GUESSING" that since ground speed is irrelevant it doesnt matter what the wheels or conveyour are doing. The whole conveyour belt scenario is a red herring to distract people away from the true reason the plane flys.(ie: lift) and the true source of thrust, (which is also lift).
BTW, thats not a guess.
Captain Ron said:So, in this "technical if you can call it that, but I'll bet on it" discussion, you'll just throw that out there and not call it a guess? You have a degree in areonuatics to back that third grade guess up with?
One, an airplane does not fly on lift alone. Lift alone does not "make" an airplane fly.
Two, Thrust and Lift are technically different vectors.
http://www.faa.gov/library/manuals/aircraft/airplane_handbook/media/faa-h-8083-3a-2of7.pdf
Section 3.
--ron
Section 3.
--ron
