trail rate this
- Cape Coral, FL
what time are both of you getting to Ed's
well, my rocky road outfitters track bar came in.
Looks sharp Greg.
I'm still mad about the incident though. I hope you like that futon![]()
both mounts are on, just need to widen one of the holes in the crossmemember. i had to cut out the studs there, drill them out, and put a nut up there and weld it in. THAT was a pain, and one of them ended up a little bit forward, so rather than fight it and probably screw up the threads...ill just open it up a bit, throu a washer on there, and be good to go.
Im also stitch welding the mounts on, along with the bolts...these suckers arent ever coming off.
Man it looks great!!!!!!! I can't wait until it's done and I can see it perform.
You can get a stud puller at HF for under $5. I have one you could've used.
