motor mount bolts
xjjunkie
york, pa
just about ready to drop the stroker in to the engine bay. i have daystar poly engine mounts, and have heard about bolting the engine brakets to the block with different bolts. (softer ?) anyone know about this ????
scot
You will discover that the Daystar POLY engine mounts are durable, BUT... the transmit A LOT of engine vibration through the uni-frame. The better choice for durability and to tranmit less vibration would be the MORE (Mountain Off Road Engineering) rubber engine mounts.
As for using softer bolts ???? Never heard of such a thing. You would want stronger not softer when building a stroker engine.
