ECKSJAY said:
Please explain how this makes sense.
bchulett said:
The benefits of incremental filtration and adding 1/2 quart of oil to a 6 quart oil pan is not worth the risk of dry starts, reduced oil pressure or possibly too high oil pressure. Just use a good reputable filter and change it and the oil every 3K miles ... if you do that you can get 250K miles out of a 4.0L.
Please don't take that quote out of context ...
My point is these motors generally don't see the kind of rpms and heat that require deep sump 7-8 quart oil pans and robust filtration ... unless its being used for some sort of race application and has a high flow oil pump.
If you change the oil/filter every 3K miles how could you actually compare or measure a favorable or unfavorable impact of installing a larger filter with an additional 1/2 quart ? If someone here tested and has data supporting the theory the motor will last an additional 50K miles, please enlighten me...
How many here employs an oil temp or trans temp guage on the cluster ?
So why take the risk of screwing a can on that may not really fit ?
Case in point:
The Fram PH16, K&N HP2004, Mobil-1 M1204 are all crossed referenced as an OEM 4.0L replacement.
The Fram HP1, K&N HP3001, Mobil-1 M1301 are all crossed referenced.
I was told in a thread here many moons ago I can easily mount the K&N HP3001 larger can on my 1991 OEM mount. So I called K&N to verify the specs as they compare to K&N HP2004 OEM replacement. Guess what ? All specs compare EXCEPT the thread size and pitch ....
So will it fit ? I don't know... maybe not exactly ... according to K&N the HP2004 and HP3001 has different threads. What I do know is I'm not going to take that chance if an engineer at K&N said it won't fit my application.
What's funny about this is the K&N HP3001 is crossed referenced to a Fram HP1 which is the same filter I use on my Race Hemi motor that has 650 HP and sees over 6,500 rpm. If you look at the both these cans you will find a significant difference in the port size on the Fram HP1 that allows better flow for high-flow pumps and can handle a motor that runs at 60-80 psi.
So have at it ...
