IXNAYXJ
- Wherever the next race is.
I've got a few more things to do after this weekend:
-----Matt-----
-----Matt-----
-----Matt-----
and looking forward to seeing some of the nicest people on earth! :sunshine:
1. Build rear bumper/tire carrier - Not gonna happen
2. Build new higher clearance crossmember - Not gonna happen
3. T-Case skid plate - Not gonna happen
4. Beef up LCA mounts - Not gonna bother
5. Move front swaybar forward an inch - Fixed sway bar rubbing another way
6. Consider installing stiffer springs in the front - Not gonna happen
7. Replace upper radiator hose that blew last night - This one will be done!
...so then you are not hanging out withall week?
:twak:
I had nothing to do, but now I need to fix a little rear steer issue, find a new backing plate, and fix a power steering leak :tears:
Replace the AC condenser and charge the AC Replaced condenser, friend has been too busy to charge system, also discovered and replaced bad water pump
Remove, repair, and re-install the front D44 ARB Done, also disovered and replaced bent alloy shaft
Re-engineer the front RE drop bracket/control arm suspension into a mid-arm 3-link. Not happening at this time
Remove Tomken rock rails, cut out rockers and weld rails in place, incorporating new front leaf spring mounts for longer leafs. Done
New 35" tires, or maybe open another can of worms and go 37s... Not happening at this time
Give the trailer a once-over. Done
