Moab Prep: Whats done/Whats left
ok, bought a tc skid plate and some axle shafts this week... means i've got all my "level 1, must happen" parts together.
unfortunately the installs will be put off a few months as i'm not near my jeep again until sept.
Oh, not a whole lot. :rtm:
Done:
reservations at Inca Inn
Need to do:
I need a drivetrain. All the parts are in my room or the shed. :doh: None of it is under the jeep.
D60- 5.13s, Detroit, 35 spline throughout, highsteer
14BFF -5.13s, Detroit, and discs.
Sleeve front half of uni-body
Slap the big rubbers on and drive it to Moab!
See you there! :party:
I just need to keep mine together, it's ready to go.
Now, if we want to talk about all the things I need to do for the event so the rest of you can have a great time, that's another big list. :D
jmaxj said:
no matter what them little ricer boys tell you it won't make your jeep go any faster wayne.
I think mine got faster, I got the flames.
DONE: Slickrock; I installed a new front Ected locker; scavenged parts from front to keep my rear Electrac locking; New Alloy USA front shafts with the XJoints; Replaced my antenna w/ glue; reset the Staun deflators; Balanced w/ Dyna Beads; took apart steering so wheel sets right side up; Sewed cover on new steering wheel; Replaced Bushwacker I smashed on Pritchet w/ Wayne; Mounted a 2nd fire extinguisher; made seperate GPS SD cards for each state; sealed Rancho shock leak;
Stiil: get some of the scratches out from all this Canadian green shit; Repair all I break in MT & Co the next 5 weeks; fix the sunroof leak; get & in my axle limit strap; get beer in Montana.
1) Install new Chromo Heims - Front Finished - not sure I need to do the rears just yet.
2) Grind off un-wanted rear/front trackbar mounts - cut off - need a little more grinding - not sure if this is going to be done on not - not really needed.
3) Install new limit straps to the shock mounts rather then chains to little tab mounts - finished and looks good.
4) Get on board air working - finished - lots of little leaks in the cage - not sure this will get fixed at this time - at least I have air.
5) Clean up XJ - Took out about 15lbs of trash/dirt/oil/rugs/carpet - looks a little better but could use more.
6) Fix steering - still needs done - have all the parts - nothing major will have this finished next week.
7) TEST RUN - need to make sure everything is ok before the big trip.
1- Dig into front diff, and rebuild old ARB
2- Waiting on Terry at Rigid for my front winch bumper
3- Paint or powdercoat said bumper once received
4- Install said bumper
5- Install new Smittybuilt winch
6- Install new towbar system with brake assist
7- Install new lighting for tow system
8- Take for test flight behind RV
9- Fix black water leak on RV
Kejtar said:
I just found out my schedule for the event might get interesting.....
And.....................?
More issues found - more issues fixed.
1) ARB solenoid - Leaking badly - ARB compressor cycling every 10sec - Fixed - Now it cycles about every 1min or so - But I am getting 90 weight back up through the solenoid. I will possibly work on this later.
2) Heat in the engine compartment - New Vents (louvers) arrived yesterday - They will be installed tonight.
3) Hood Pins not fitting correctly - Fixed
4) Tires are way unbalanced - Dynabeads ordered - Will install them once they get here.
I managed to develop some issues over the weekend..
Need a hood....
:D
Somebody was nice enough to make me a list. Guess I should get busy...
Front Dana 60/Front Suspension
v[FONT=&quot] [/FONT]Weld Truss
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]Setup for appropriate caster 5*-7*
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]Center coil buckets under buckets on XJ using plumb bob
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]Lower control arm brackets positioned—take into account u-joint on driver side
v[FONT=&quot] [/FONT]Weld unibody stiffeners
v[FONT=&quot] [/FONT]Front steering box reinforcement plates
v[FONT=&quot] [/FONT]Steering
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]Install Hi-steer arms
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]Consider modifying current inverted T vs building full crossover
§[FONT=&quot] [/FONT]Need Tubing, bungs, TRE
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]Possible modification of track bar length/mounting height
v[FONT=&quot] [/FONT]Sway Bar Mounts
v[FONT=&quot] [/FONT]Install Gears/Detroit
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]Find U-Joint size for front DS
v[FONT=&quot] [/FONT]Breather Hose
v[FONT=&quot] [/FONT]35 spline inner/outer
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]35 spline Warn lockouts
v[FONT=&quot] [/FONT]Brake overhaul
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]New pads
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]New rotors/turn old rotors
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]Modify XJ stainless flex lines to work with Ford caliper
v[FONT=&quot] [/FONT]Machine hub or H2 rim for clearance
v[FONT=&quot] [/FONT]Install Cover
v[FONT=&quot] [/FONT]Fill with fluids
Rear 14 Bolt/Rear Suspension
v[FONT=&quot] [/FONT]Plate housing
v[FONT=&quot] [/FONT]Install gears/Detroit
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]Figure out U Joint Size
v[FONT=&quot] [/FONT]Finish Rear Discs
v[FONT=&quot] [/FONT]Weld UBE/Shock mount
v[FONT=&quot] [/FONT]Plumb brake lines
v[FONT=&quot] [/FONT]Fill with Fluid
v[FONT=&quot] [/FONT]63” Chevy Leaves
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]Plate Unibody for new mounts
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]Build new front/rear mounts
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]Build Shackle
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]Remount rocker guards
v[FONT=&quot] [/FONT]Traction bar
[FONT=&quot]o[FONT=&quot] [/FONT][/FONT]Axle end mount , tubing, crossmember mount
Brakes
v[FONT=&quot] [/FONT]Plumb new brake lines as needed
v[FONT=&quot] [/FONT]Install new MC
v[FONT=&quot] [/FONT]Bleed brakes
v[FONT=&quot] [/FONT]E-brake?
Other
v[FONT=&quot] [/FONT]???New DS Front/Rear???
v[FONT=&quot] [/FONT]Lug Nuts
v[FONT=&quot] [/FONT]TRIMMING!!!
v[FONT=&quot] [/FONT]Why isn’t OD/TC lockup working?
v[FONT=&quot] [/FONT]CB Radio
v[FONT=&quot] [/FONT]Rebuild RE Flex Joints
Possibilities
v[FONT=&quot] [/FONT]Hydro assist
v[FONT=&quot] [/FONT]Front/Rear Bumpers
