MOOSE16285
- Memphis, TN
DOES THE cps end look like a round thing with a small prod thing. i think i got the right thing, i'ma go clean it real quick. brb
On what scale?MOOSE16285 said:that would be it... so i stick both leads on to the same lil prod on the end of it?! I did that and got a .02 reading on it...
It will in the Ohms setting, either type meter reads OHMS using the battery.Weak batteries in an electronic meter, don't often cause problems
Does your fuel pump run for 3 seconds when you turn your key on? If so your ECU is running. You can also take a portable AM radio tuned to 1100 AM place it near your ECM and turn the key on, you will hear a tone/hum if its running.MOOSE16285 said:Okay, Autozone carries the CPS but not in stock so I'ma check NAPA today after the airshow. IF this is not the problem, whats next? Leaves ECU right?! hmmmm...
I can hear my pump by reaching in side and turning the key on, it runs for three seconds and is pretty loud. The ECU is a computer sound, you don't need to turn the key to start, just to "ON"MOOSE16285 said:Okay, definitly a srong humming thing but its not a tone, not constant... its a hum that varies a lil... the starter wouldnt put out any frequecy would it, cause the hum came at the same times the starter turned... i need a 2nd person for the fuel pump ut i poked the fuel line pressure release stem n fuel came out... so i assume for now its pumping... but will test the pump later after the airshow... if its not the ECU, i'm getting a CPS, what else am I looking for now?! O2? MAT?
