JnJ
- San Antonio TX
cingtek said:gotta love the closed-mindedness around here.....:twak:
Naw, it's just one idiot.....
Or taking a Lincoln and making it an SUV with a fold down tv with DVD.CUxj88 said:Jeeps go up not down, if that piece of s*** ever showed up or any other lowered jeep i'd make every attempt to slash their tires...it's just wrong that's like lifting a cadillac 13 inches and putting swampers on it... you just dont' do it
Brian Felts said:There is hope for you I used to be a hardcore lowrider freak until i became a land owner my lowered S10 is sitinng under a tree collecting sap
dont go any where withot my cherokee. think ground clearance
Forum Fixer said:This forum has been created for people to discuss modification and tuning issues related to street XJ's.
This may include lowering XJ's, or just performance tuning a stock suspension XJ and more.
IF you do not care for this type of modification, that is fine. Bashing or rude comments towards posters will not be tolerated.
As always, the "Report This Post" feature is the best way to deal with a post that is out of line.
Enjoy the forum!
aspera said:
Third is aftermarket support and availablility. A bazillion Cherokees were made. Everybody has been making cheap parts for them for over a decade. Even Ford has unknowingly been making parts for the XJ.![]()
Naw dude, you're doing the opposite of what I'm doing next weekend, so let me spell out the way I see it. First, yeah, you've got your axle tubes, whether it's like 2.75" or 3" I dunno, depends on whether it's a D35 or an 8.25". Plus you've got the thickness of the leaf pack, so that's like another inch or so. Then you've got the old and new spring perches. Sure, on the bottom you could do basically a flat plate welded to the tube, but I think you'd still be about 1" between the two. So I'm seeing like 5" or so. Just a little bit more than 4", but I think you'd have to get creative with tire diameter and width, and wheel width and backspacing, and sheetmetal relocation to make it work. Oh yeah, and when you go SUA, the spring plate, and so U-bolt ends, are underneath the axle tube also. And you'd have to do raised shock mounts, I think, because they hang down kinda far on lifted XJs, forget about on lowered.91XJlimited said:Back to the actual lowering concept....SUA would be the best route. Not only would it lower it, but still give it the same load bearing characteristics instead of giving it weak leaves, or less leaves. It wouldn't drop it to the ground, only the width of the axle. So maybe like 4"?
