Since I last posted in this thread a year ago, we've competed in two more 24 Hours of LeMons events. We finally got around to doing our 8.8 swap, but otherwise the set-up is the same as when we first guesti-fabbed it up. The results have proven to be fantasticly stable and reliable.
We're running stock springs in front with a little more than a coil cut out, stock sway bars and the old shocks that came with the truck. In the rear, we converted it to spring under by plasma cutting off the stock spring perches and flipping them upside down. This netted about a 6" drop, so we added a Rubicon Expess Add-a-leaf to bring up back up.
As I mentioned, we've since added an Explorer 8.8 (disc-brake, 3.73, LSD). While we were at it we fabbed up some different spring perches using some MJ bits. Really, it was fairly simple for even the most basicly equiped back yard fabricator. Here are some pics of it in our last race, in which we won our class:
Sure we could make it lower, yes it rolls a little bit in corners, but in a sustained, high lateral g corner, there isn't much that can hang with us. The thing is truly amazing to drive, and it's really fun to pass a bunch of sports cars in the twisties. If your goal by lowering the Jeep is to look cool, then do what you want. If you want it to handle well, then do what we've done; it flat out works.
Check out our YouTube Channel with some in-car clips:
Our YouTube Channel
http://www.youtube.com/user/TeamPettyCash?feature=mhum#p/u/11/ftMxEh7xZvs
-Matt
