REDXJ4FUN
- fredericksburg VA
Ok we need more tech on lowering now. my 2wd mj is begging for some mods.
What's to know?REDXJ4FUN said:Ok we need more tech on lowering now. my 2wd mj is begging for some mods.
I'll venture a guess the handling got worse because of caster/camber changes (can't recall right now which is which, so I'll use both). Your tire basically titled in at the top making for slightly better overall cornering, but less of the contact patch on the road. This may also make the front end darty when steering - seeming to want to change direction *NOW*...eric91xj said:It actually handled worse because after a few short months my front shocks were dead some how so it felt like i was driving a boat on the road, i guess this could also be because the whole front end geometry was way off. Braking and traction in the rain and snow got considerably worse because the rear end was so much higher and lighter with no rear seat or spare tire or anything back there.
MalakaiKingston said:
Those are some of the issuse i'm working on right now. I'm goingto be making new control arms with poly bushing ends but the whole conrol arm angle has we wondering how to work that out. at one time a company used to make a drop knucles but they are no where to be found. I know Phil weeks had a thread bout moving the LA mounts in board and up awhile back. I hope to have some tech on this soonsportsguy said:I'll venture a guess the handling got worse because of caster/camber changes (can't recall right now which is which, so I'll use both). Your tire basically titled in at the top making for slightly better overall cornering, but less of the contact patch on the road. This may also make the front end darty when steering - seeming to want to change direction *NOW*...
...the ride quality would have gone down as you effectively increased the rate of the spring by cutting it - resulting in a harsher ride - which is what toasted the shocks.
jeepinxj05 said:make it bigger!!! it hurts me to think your gonna lower it
OK, we need to have some kind of pre-post test to ensure folks get the simple fact that what you do to your Jeep is a personal choice and there's no need to rub it in to others if you don't agree with it.jeepinxj05 said:make it bigger!!! it hurts me to think your gonna lower it
:soapbox:sportsguy said:I wonder how many of the folks bashing those who want to lower a rig have ever wheeled their own trucks stock? I have and I can say that (within limits) it was plenty fun and very capable. True, being lifted let's me do more off-road, but to each his own.
Thanks Sarge hadn't thought of that...:lecture:Sarge said:Then don't come read this forum.
Sarge
:wstupid: I've seen a few caddys lifted that much- (escalades)- and the funny thing is even though they were ment for show- with all the money they have in 'em, they'd tear the crap outta my rig offroad:roflmao:Majo said:Jeeps go up not down, if that piece of s*** ever showed up or any other lowered jeep i'd make every attempt to slash their tires...it's just wrong that's like lifting a cadillac 13 inches and putting swampers on it... you just dont' do it
gzweber said:Wow, it sure is crazy how ****ed-off people get about someone making a jeep fast or lowering it. Well here is something that should really **** anyone off that has a lifted 4x4 jeep. I have an 89 xj with the 4.0, aw4 tranny and 242 t-case all of which worked perfectly. Well it all worked until I tore it down to the unibody. I just got a new 242 with 30,000 miles on it and guess what it's 2 wheel drive mwhaaaaa hahahahaaaa. It will turn my 20 inch rims very well indeed. I had custom perches and control arms made for my coil springs on my ford 9 inch rear and I used a Frankenstein-like combination of parts to convert my front end to independent suspension. If that wasn’t bad enough, it will be able to sit on the ground with its air ride suspension. So what am I going to do with my transfer case???? Well…I think I’m going to melt down the aluminum and use it to make some big emblems that say 2X4 and put them right on the side of my jeep.
aspera said:This is the forum that I've been looking for.
The XJ can be made to do almost anything. Obviously it can offroad, but it can race and drag too. It might even autoX!THAT would be something. I'd like to see a rally Cherokee, though. That would make everyone happy. It would be built for the road, but would sling gravel to make the offroaders happy.
