exgreenjeep
- Stoney Creek, Ontario
i have a 2001 xj with the low pinion 30 should i swap in a high pinion 30 or is the low pinion ok?
Colorado_XJ said:And if I was gonna build the rig, I'd swap out for a 44 anyway.
Colorado_XJ said:If you had one of each kicking around, sure. I wouldn't think there aould be any reason to go out of your way to do it, though. As for the 35's...that YJ is a lot lighter on a shorter wheelbase (less leverage) than an XJ. Glad you had success earlier...sorry someone stole it...and I hope your good luck keeps up.
-Rich
exgreenjeep said:i have a 2001 xj with the low pinion 30 should i swap in a high pinion 30 or is the low pinion ok?
That's why DC changed from HP to LP. If you lift then HP is fine.Capt. Nemo said:Just make sure you have enough clearance with the exhaust manifold if you're staying close to stock ride height. I was thinking about swapping in a HP in my 2000 for more strength, but the manifold looks like it might interfere without a lift.
exgreenjeep said:i have a 2001 xj with the low pinion 30 should i swap in a high pinion 30?
GSequoia said:YJ's are heavier than XJ's, crazy ain't it?!
exgreenjeep said:i ran 35's on my yj for 4 years, so i'm not concerned about 35's on the 30
