Looking for an XJ/MJ or cheep 4x4
I've got a shaft, is it auto or manual? Get a tape measure and get me a length, and I'll put a shaft together from decent pieces next weekend and send it home with Jes.
Is this for some sort of Comp? In other words, will a worn out, ghetto shaft work?
Letterman said:
With big thanks to Eric (Capt. Nemo) I am again a owner of an XJ!!!!
47b6df08b3127cce977fde18e89d00000016108IasWTVu5aE
Thanks again Eric, and if you ever need any welding done, or you want to borrow my tube bender let me know!
Hey, part of that Jeep has run the Hammers. ;)
Are those LeBaron hood vents? Sweet.
the thing is a stick, I will try to get under it to messure, any POS drive shaft will work, only has to make it up a trail once!!!!
Also anyone know about green stickers? How much are they? What do I have to do to get one? I will check with the DMV but if anyone has done the foot work and has info that would be great.
I'll send one down with Jes.
If that's a Renix rig, I'll take the wiring and computer, if it's not burned to a horrible crisp after your, uh, "activity".
ChuckD said:
I can use a 231 with an HD SYE! :D
I've got one sitting (uselessly) on my garage floor!
This is a little too interesting to leave alone...
Obviously this is for a one time run sorta thing... so what is it? Or is that super-secret?
-jm
HTeK said:
awesome... really a great idea and it should turn out to be quite a fun event. if you guys dont take any pics i will personally bludgeon you.
All are welcome to come watch or even try to put a rig up the trail.
I wish I knew more about XJ's, like how much lift can I get away with before I have to do a SYE?
and How much do I have to cut to fit 37's?
and how far will a lincoln locked dana 30 make it before it blows up? ;)
Letterman said:
I need some stuff, mostly I need a front Drive shaft if anyone has one for cheep or better yet for FREE, Please hook me up! I could also use a drivers side fender if anyone has one that is beat up and they don't want anything for it.
Last I need tires, but I am willing to pay for some tires and rims, PM me if you got some with just ok tread 33's or bigger.
David
Hey! I can paint it for you David. Do you like Cooler Red?
Can't beat this color :
ccflexj said:
Some one has to post up when the "event" will be. If David makes it up, I will throw in a 6 pack of Sierra Nevada. I gotta see this!
I would say 4"s without a SYE and get out a cutting disk and take off all the fenders and 37's will fit. Heck, weld up the front too it is pretty straight up Tank Trap. Get some steel plumbing pipe and weld that up for a front drive shaft. Should work long enough for one run.
