riverside
- Riverside CA
92, XJ, 4X, do the axles ever lock (i.e. wheels always turn no matter what). I got stuck where the left rear was spinning and no other wheel was turning, both in 4 high and 4 low.
The transfer case options for you model year were the NP-231 with Part-Time 4x4 or the NP-242 with both Part-Time and Full-Time 4x4. Part-Time 4x4 High and Low are for slippery surfaces ONLY, do not use Part-Time on dry pavement. Part-Time 4x4 drives both axle equally, but the axle differentials will allow the tire with the least amount of traction to spin. The real solution to this is a locking differential.
It is common for the 4x4 floor shifter to be out of adjustment and/or to need new bushings. A transfer case that is not used much is often stubborn to shift between modes, and to return to 2wd.
When I am in low 4X the front wheels spin at the same speed so applicable only on the dirt? Does not seem to happen in high 4X, am I correct in this?
Also, what happened with one wheel spinning is to be expected? The solution, in that case, is to provide more traction (weight or traction bar) for the spinning wheel? Thanks, good to know this before I adventure too far!
