well that kinda says it in a nut shell, I'am a little lost at which to do first. I plan on going with the bds 4.5 long arm lift kit but iam not sure weather i should install that then reinforce the unibody or try it the other way around.
For the unibody i plan on 2x6 rocksliders welded into the rocker, welded rollcage, and ruffstuff chassis reinforcements is this overkill for a mild wheeler?
After going through the bds install instructions online i do believe the extra 3/16 on each rail will mess with the replacement trans crossmember. I dont what to start off by making a weak piont though i suspose i could alter the crossmember a bit to make it work ...
what does everyone think install the lift kit and reinforce around it or plate the unibody the try to make the lift kit work?
