boomer1
- Northglenn, Co
Been working all day changing out a rear axle. Have a 4.5" RE lift on the rear and since it's all tore apart - need to see if someone can help with a question.
The rear rubber section of brake line that runs from the unibody frame, down to the axle is streched pretty tight. On one end, on the axle, is a block with the two hard lines going to each hub. On the other end, on the unibody, is a bracket with a single hard line connected.
Is there anyway to get a longer rubber line. Any lines off some other model of jeep longer and still hook up to the factory hard lines? Or can I just go to the parts store and ask for a longer one?
Going to hit the parts store tommorrow and hopefully get this thing done and back on the road.
Thanks in advance for any help.
