Leak
imthehink
Tulsa
Cannot tell where it is exactly where it is coming from. It pretty much leaks in just that area. I've cleaned and wiped everything down to get a better idea but still can't tell. It looks and smells like power steering fluid. Ideas?
Check the compression nut ontop of the radiator on the driver side; it may be the compression nut to the transmission cooler. I have the same leak.
I know you said T Fluid, but looks like a PS fluid leak I had once. The plastic fitting that went into the PS Pump Reservoir had a hairline crack. (Which I caused while pounding a motor mount bolt into shape :D )
Ok, I just cleaned everything again and drove for about 10 minutes. I found it. The t fluid is leaking from this crimp on this hose: What's the part name and where can I get it? Thanks
imthehink said:
Update: It was the power steering line. I replaced it. Leak solved. Now i have no power steering. Help lol
Is there enough ps fluid in the resevoir? Did you keep purging the air by going from lock to lock with the steering wheel?
