Cannot tell where it is exactly where it is coming from. It pretty much leaks in just that area. I've cleaned and wiped everything down to get a better idea but still can't tell. It looks and smells like power steering fluid. Ideas?
I had that same leak from the top compression nut as well. I got so tired of dealing with it that I purchased a trans cooler and bypassed that connection.
I know you said T Fluid, but looks like a PS fluid leak I had once. The plastic fitting that went into the PS Pump Reservoir had a hairline crack. (Which I caused while pounding a motor mount bolt into shape )
Ok, I just cleaned everything again and drove for about 10 minutes. I found it. The t fluid is leaking from this crimp on this hose: What's the part name and where can I get it? Thanks
Its called a transmission cooler line and I think that is the return line. It cycles trans fluid through the radiator to keep it cool. Anyway, I think that one is the return line and you can buy it at most auto part stores.
