POSrenix
- simi valley
anyone have experience or opinions,suggestions on swapping longer springs from other vehicles or better to stay with standard lift
Does Deaver sell direct? Any decent online retailers for Deaver?
I'm on the east coast -- Looks like the only NJ dealer is a hot rod Mustang/Raptor place
Second on the Deavers. Just put a set on mine and the ride improvement is incredible
Did you buy leaf's for XJ or different application?
I bought their off the shelf XJ 4" leaf packs. Going to test them out this weekend
I had some full size dodge van leafs which are basically bolt in. They are longer from the centering pin back. Definitely want shackle re-locators to dial in the angle. Flex was really good and it was a cheap upgrade. Beware the front eye on the dodge leaf spring bushing, atleast the one I had, was a touch larger than the stock fastener for the XJ front eye bushing.
How much lift did you get? let me know how they do.
Looks good, but it also looks like you need a spring with more distance between the front eye and the center pin to move that axle back more (or put on some offset spring perches).
Offset blocks were put in. I think 1.5” it pushed it back as far as anyone would want to go really.
Moved onto triangulated 4 link and coilovers
