XJ_Otto
- Nashville, TN
Twins! Sweet jeep man. The only thing Ill add about the rear sway is that it will help if you tow anything. So keep it around just incase. Anyway, great looking XJ.
What SYE did you go with?
Thats a nice clean double duty XJ you have. I am new to the XJ world too and am loving it. Props to the ones that caught the self wheeling and empty off camber parking.
Its just a Skyjacker 3" lift, nothing crazy.
the stock sye, the 97's and newer come with a sye if im not mistaking
No Cherokee came stock with an SYE....If you got that much lift with out needing one, you're very lucky!
High travel Slip Yoke, if I understand it correctly, would be just a longer slip yoke.
A SYE eliminates the slip yoke, and uses a CV (constant velocity) driveshaft. A CV driveshaft is designed to adjust based on the height of the vehicle. If you look at your stock front driveshaft compared to your stock back drive shaft, you'll see what i'm talking about. The front DS is a CV shaft, and you'll see where the driveshaft will extend as the vehicle is raised, where as the rear is a solid shaft and the slip needed is where it connects into the transfer case.
If you don't have any driveline vibes, I wouldn't worry about it. 4.5" on a 97+ model, a SYE is almost a necessity. Chances are they probably atleast put a transfer case drop on when they did the lift. Sometimes a 1" tcase drop can take care of the vibes.
wont mess anything up but personally a SYE and CV Driveshaft is the better option...
my wrangler has 4" lift and 1" drop when i got it and i swapped out the 1" for a SYE and CV DS instead
one of the benefits with the SYE and CV DS is that your transfer case skid/crossmember stays up by the frame instead and that keeps it out of the way of rocks and stuff...
not a huge deal but something i would consider when you get the $$$
Sometimes a front XJ driveshaft will work in the back when doing a SYE. And I believe your model is one of them. I used a front in the back of mine when I broke one of my rears and only had to carry 1 spare shaft.
