- In the islands
Are you going solely by the tach, or have you confirmed the actual rpm with a scope or scan tool? Either way I do not believe that extra 100rpm is much of a bother.
WOW!! I had to read this entire thread again,....the intrigue,....the suspense. Lots of opinion, lots of advice, and lots of testy people.
Back on topic,....
No, I have not tested to see if the OEM RPM guage is correct knowing fully well that the dash instruments are not calibrated. The MPH though is GPS verified to within 0.XX of what the MPH guage reads, and yes, I changed the speedo gears to match the diff ratio and tire size combination.
Maybe the AW4 have more clutch slip than it should have when it is in overdrive. It have been this way since I bought it in 2003 at 125,000 miles. It is now just shy of 270,000 miles. I do not look at the lower gears since they are only used when starting off or driving on city streets.
