chris420
- California
I needed to make my XJ unibody stronger. The driver side was flexing even with 32" BFG AT's. I ordered the JKS SBS system for both the driver side and passanger side. I currently have an ARB bumper and fitment was a concern sence the ARB is already a tight fit on the unibody. No one has posted a wright up on how to fit an ARB bumper to the JKS SBS system so I figure I better document it to help other people with their concerns. Please be patient with me during this post as I will be adding several pictures tonight.
You need to sand down all the paint off the unibody rails inner and out with an 90 degree die grinder. I used a 4.5" grinder on the outside rail and 60 grit sand paper with my hand on the inside rail. Trust me buy a diegrinder for this job I feel like I wacked off for day's. After I sanded everything down to bare metal I spayed it with Duplicolor Weld through primer. Some one on here told me that the Weld through primer causes splatter and it did. I am glad I masked off the unibody in the areas that I needed to weld but the plates I needed to sand down with a wire wheel. Below are some pictures.
1. Driver side inner prepped and ready to weld
2. Passanger side inner prepped and ready to weld.
4. Driver side outer prepped and ready to weld.
5. Passanger side outer prepped and ready to weld.
6. Crapy Duplicolor Weld Through Primer. It probably help protect against rust but causes splatter.
7. Here are all the parts that the kit comes with. The passanger side is identical to the driver side.
8. You need to strap the steering box out of the way in order to gain access to the unibody. I used a hanger strapped to the hood latch to keep it from falling and a ratchet strap to pull it towards the passanger side. It was still very difficult to get in there and I was not able to fully weld around the sleaves because my gun could get in that small area very well. I do not feel it is neccesary to fully weld the sleave on the inside plate.
9. You need to bolt the steering box into place using the supplied hard ware before you begin to weld. You will notice that I also placed the bumper bolts and the back tow hook bolt in and secured them to insure that the brackets were in perfect allignment before I began to weld. I did need to enlarge the holes on the inner bracket for fitment.
10. The ARB bumper bolts to the bottom of the unibody and the sides. No other bumper on the market bolts to the bottom of the unibody. I feel the ARB bumper is better than most bumpers due to its unique bolt pattern and that this bolt patter helps spread the load to the unibody. Unfortunatly due to the ARB's bolt patern the tow hook option can not be used and you need to hack off the portion on the outer bracket that is used for the tow hook. The ARB bumper comes with intergrated tow hooks so no need to worry just hack away.
